Welcome to the forum. I'm a hotrodder from the late 60s - early 70s and really enjoy my Crossfire. I haven't had a car this fun to drive in a very long time.
You'll find this forum is holds a wealth of information. The knowledge contained here and in its members will save countless dollars and hours should your Crossfire needs any repairs. As an example my 04 coupe had the check engine light come on last year. Armed with the error code pulled for free at a local parts store, I came to the forum where I learned it was a problem with the relay control board. If I'd taken to the dealer they would have replaced the module for $300+, but I found step-by-step instructions on how to open the module and clean one of the relay's contacts. At the same time I checked the board for cold solder joints (common problem) and resoldered the relay joints just in case. Put it all back together and problem solved. My cost = ZERO. Time = 40 minutes. Membership to this forum = Priceless.
Tom
