Old Dec 26, 2015 | 12:46 PM
onehundred80
Default Re: BAS/ESP No brake lights
Originally Posted by davidf30
Hi. Finally back on line. Thx for the reply. All the bulbs are fine. Got bas/esp light to go off and brake lights to start working again last night by removing the #2 fuse and putting it back in but not all the way. When fuse is pushed in all the way problem occurs again. I need to check this forum. I think there was somebody who was doing that exact thing and posted about it. Need to see if he posted exactly what he did to fix the problem
There was a problem once and it was because the terminals in that fuse panel for a fuse had got bent and the fuse did not fit in it correctly. Check the condition of the fuse box terminal.
The fuse box is actually in the side of the ICM, Illumination Control Module, or in normal language - the light switch.
