Old Dec 31, 2015 | 05:23 PM
godthehamster's Avatar
godthehamster
Default Re: Speakers, need new ones.
so I got the door panel off, broke the tab on the sail panel, thing was stuck, even after breaking it I could not remove the tab with needle nose pliers. sheesh.
So how do I go about removing the speaker from the mounting bracket, this thing is completely glued in, is there a way to remove it without destroying the thing?
Edit: Got it, ran a thin flat blade screwdriver around the speaker from the back of the mount and was able to cut some of the glue, then just used pressure to push it out from the weakened point. kinda tough tho. that thing was in there.
