Lordbass
Any tips on wiring the fog lights as drl lights?
Thanks
I actually wired them up straight through a 10A fused 12v 4 pin relay triggered by a 12v ignition switched source in the fuse box under the bonnet and I ran the wiring from there down to both fogs.
But if I had the wiring diagram for the LCM I would have done it all at the source so there wouldn't have been any need to run wires down to the front but at the time I didn't so that's why I did the way I did.
It was a very simple mod that took around 15mins as you can access the rear of the fogs through the 2 access panels in the splash shields
