Re: Which wiper blade refill?
Mackel
I need new wipers because the rubbers are shot. I'd like to keep the original blades and just replace the rubbers but I'm having a tough time
finding ones to fit. Most on the market fit square claw blades and apparently we have trapezoidal shaped claws. I assume I have OEM blades
on the car as the driver's side blade (the short one) has an air spoiler built in. Replacement ones don't have this.
Surely one of you folks has done this.
What refill did you use and where did you find it?
The claws that hold the refill are parallel to the glass on the OEM ones I have had. They are designated trapezoidal claws. I had an '04 from new and the ones on my '05 are the same. I put refills in both at some point. Yours is an '05 so they must have had the blades replaced at some point, maybe the whole assembly. Rubber does not last long even on low mileage cars, it just gets old and rots.
The refills were rubbish so now I replaced the assembly with Bosch Icons, no spoiler but I will keep looking for replacement blades. Someone here said that BMW sold replacement refills that fit.
Reason: Trapezoidal correction added
