Old Jan 2, 2016 | 09:21 AM
onehundred80
Default Re: Which wiper blade refill?
Originally Posted by BisB
Here is my experience replacing wiper blade (refills) and retaining the OEM wiper arms: I brought the entire driver side wiper blade into an O'Reilly Auto Parts store for assistance. I did this after several attempts to find the wiper blade refill with no success. The very helpful counter person located a Traco blade (I'm fairly certain it was Traco) that had the same style blade/rubber trapezoidal claw twin wiper blade. So I purchased the entire wiper arm and dismantled/removed the rubber blade from the new blades to only use the rubber blades and rails in the OEM CF wiper arms and tossed the Traco arms. I have some notes in my CF file that indicate a Traco "Exact Fit" 46 series "narrow" blade. Not sure if the notes are accurate but are what I saved after the wiper arm purchase adventure. I recall the swap was not easy. I have only replaced the rubber wiper blades one time in 3 years owning the CF. The entire process was time consuming but was achievable to keep the OEM wiper arms, especially the driver side that has the "spoiler". The wiper arms were not that expensive so none of this will break the bank, but WAS time consuming. What else is new with the CF. Oh yes, I called Mercedes parts and used a VIN number from from an SLK 320. The price of the blades were ridiculous but I only made that call to see what the shortest route may be to obtain new blades. The Traco 46 narrow series fit the OEM arm (if my notes are accurate). I'm sure my blades may need to be replaced in the spring so I'll be doing this all over again. Look for Traco and prove me correct. Hope this helps!
Up here in Canada we have the make TRICO, there was a plant near Hamilton at one time. I believe the trapezoidal in the name refers to the shape of the blade.
TRICO is still going I find now.
I found the refills in Canadian Tire up here, you cut them to length as required, you want the narrow width - 5mm?. I am not to sure they were there last time, I purchased Bosch Icons, sadly the whole assembly.
On looking I find that SWF is a European maker of windshield wipers and they fall under the Valeo owned company's. CLICK
Look down the page and find our Windspoiler design.
