Old Jan 11, 2016 | 01:26 PM
onehundred80
Default Re: S.C. - Clutch Plate Pulley Assembly
Originally Posted by Fla_Xfire_SRT
................The used pulley had less meat on the coupling disk or backplate and stood off from its mating surface approx. .030 more than it should. .....................Concerned, that is, until I get scattershields installed.
Do you mean that the clutch plate does not sit on the three stops like it should? I doubt that there is any material missing anywhere to make parts thinner by any appreciable amount.
If the clutch plate does not sit back against the stops then the dog bones have been stretched too far at some point.
I would not rely on the scatter shield to save you from all damage, I am sure it will save a lot but all? I am not so sure.
