Old Jan 12, 2016 | 10:07 AM
  #38 (permalink)
onehundred80
Default Re: S.C. - Clutch Plate Pulley Assembly
Originally Posted by Fla_Xfire_SRT
Brrrr...cold out there this morning too...36F. ..I'll try to post this in the thread, if it doesn't work, the pic will be in my photos folder somewhere..sorry, first pic post in a thread. The pic is a closeup showing the clearance and the oem pulley with the new bearing in it.
Looks OK except the gap is too much, you need to remove some of the shims to reduce the gap to .012" to .016". All the pulleys and SC mounting faces have a tolerance and the tolerances add up.
The thicker plate on the pulley that grenaded needed more shim thickness than you do now.
