Old Jan 17, 2016 | 01:24 PM
  #58 (permalink)
onehundred80
Default Re: '04 Coupe Liftgate lock failure
Originally Posted by longspoon
If it is the airline that has fractured my bet is it will have done so where the line enters the tailgate door as this is the only area that moves. If earlier threads are correct pressure does lock and vacuum opens. If fracture occurred after the lock was in a closed position, then as there is no vacuum to open it unless access to the line between lock and fracture or at the point of fracture is made, one would seem to be snookered. Hence my original question was the lining removable with the door closed.
I think if you read post 33 you'll see the area of the hose break mentioned and if you read the post 54 you'll see I answered that the trim can be pried of with the hatch closed but you have to be in the trunk to do it of course. I think a vacuum opens the locks, you can also get at the hoses by taking the wheel cover trim off and blow or suck on the air line for the hatch and passenger door, naturally from inside the closed trunk again.
