Old Jan 18, 2016 | 11:56 AM
ala_xfire
Default Re: Water Pump Replacement
If you DIY, then :
Lay the new one down and insert each bolt you remove from the old pump into the matching hole of the new pump.
When the old pump is removed, swap all the bolts back to it.
As you install the new pump, pull the matching bolt from the old pump.
( the bolts are different sizes and lengths )
