ala_xfire
If you DIY, then :
Lay the new one down and insert each bolt you remove from the old pump into the matching hole of the new pump.
When the old pump is removed, swap all the bolts back to it.
As you install the new pump, pull the matching bolt from the old pump.
( the bolts are different sizes and lengths )
thanks for all the info I just ordered the WP from Rob at Needs wings
Think I'll change the Belt also start fresh.:
