Old Jan 29, 2016 | 11:32 AM
onehundred80
Default Re: Security Control Module
Finally getting to Crumpy's Security module repair.
What a mess under that foam. Appears the previous owner had already been in there.
What I cannot find is a new module. Mercedes says they "have no idea from the part number"
Does anyone know the Mercedes number for the part?
Delphi A 193 820 01 26
Otherwise I'm going on Fleabay.
Thanks
Dave, I was hoping you would see this. Thanks
Well, my first encounter with a Mercedes parts Dept they said NO.
The Pump is fine. It is the relay that is corroded. Circuit board is covered in corrosion.
I will be sealing everything up in plastic and silicone. I just need the part. perhaps another stealership will be more helpful.
The one on E-bay is used. I'm going new if I can source it.
What relay? Inside the pump?
Is it shown in this thread? (CLICK)
