Old Feb 2, 2016 | 10:51 AM
onehundred80
Default Re: is there anything that would keep coolant from reaching the s/c
Originally Posted by Mr5150
Sorry didnt get any of the bay just underside. Standard NW dual intake. Everything is stock and leaky valve covers.
Is it possible that the IC is plugged up? I guess you could run water through it with a hose. Or disconnect the return line from the IC with engine running to see if there is any flow.
If there is a build up of crud in the coolant then small passages trap the crud and eventually block up solid.
