Thread: Oil leak
Old Feb 3, 2016 | 01:34 PM
pizzaguy
Default Re: Oil leak
I see your oil leak and raise you my TWO leaks.
Mine is an 07 and it started the same crap a month ago. I have it leaking from both sides. The culprit is the seal between the valve covers (called cylinder covers in the manual) and the little breather cover that bots onto the valve cover. They used a trashy sealant there.
I ordered new sealant, new bolts and new valve cover gaskets -might as well do it right. $88 for the bolts and gaskets, you can buy the RTV locally.
I will be tearing my off on Saturday and taking care of this. Welcome to the club! If I can find it, I'll post the DIY procedure, but if I don't Ala_xfire will.
Where is St. Charles?
