Re: Valve cover leak...
Ok, got it. Now, I tried pressing on the little needle on the end of the fuel rail (used for measuring pressure?) and I got nothing but a small drop of gas. The car had sat four days at this point - would it be normal for the fuel pressure to bleed down completely in that time, Rob?
Also, anything I should know about removing and reconnecting the line OTHER than the obvious: do not allow ANY contamination in there? Obviously I will reconnect and check for leaks under pressure before I drive the car....
(I'm about to use the bolts and gaskets you sent me!)
