Old Feb 8, 2016 | 02:10 PM
kingdavid54's Avatar
kingdavid54
Default Re: Newbie with indicator problem
Originally Posted by audiohotrod
Yeah thanks I did think maybe should investigate that as there was so much water. It has rained constantly forever this winter but even so it was an impressive amount!
I've removed the lower bung on each side so anymore should drain away in the meantime.
I was obviously too pleased with my fix to contemplate the next step!
Thanks for your advice.
I own a roadster not a coupe but if I had to make an educated guess I would say the first place to look for the water leak is around the hatch seal, also some members with the water problem have encased the pump in a plastic bag and sealed it up with wire ties.
