Old Feb 11, 2016 | 08:37 PM
kingdavid54's Avatar
kingdavid54
Default Re: Familiar Starting Problem
Originally Posted by chili
Forum contributors I am sorry to say the saga continues. My fuel gauge still does not work. I had an independent shop test the fuel sending unit that the Chrysler dealer put in and they confirmed the part is good. They could not check the programming because Chrysler software is needed for that so I went back to the dealer and they rechecked all their work INCLUDING the programming (at no cost)and said everything was done right. They want to replace the dashboard cluster.
The gauge worked before the car stopped dead. The replacement of the fuel level sending unit and the engine control module have it running great except for the gauge. The dealer wants to replace the dashboard cluster unit and I said no! That part is expensive, hard to find and all of the other gauges work. Surely there is simpler answer.
HELP!! The car is terrific cosmetically, has only 17,000 miles and is fun to drive. I don't want to give up on it unless it's a money pit.
Chili
The question you should have asked them is if my fuel gauge was working when it came in why did you replace it.?
