BWilson
Hello All,
...... and removed the battery cables and it will crank twice and die each time. .......The engine will still crank twice and go dead each time.
BWilson
Read posts 6 and 14 again.
George already answered this question - the SKREEM is not recognizing the RFID chip in the KeyFob - you have a bad SKREEM OR the ring around the ignition key has come unplugged from the harness, which makes the SKREEM not recognize the RFID in the KeyFob.
I do not know if you can get a SKREEM replaced anywhere other than a dealer. The job of changing the SKREEM takes about 1-2 hours. This should cost $200 or less plus the part, which is somthing like $350.
Typically, the dealership will see you coming and charge $800 to $2000 for this, because they are that dishonest.
Very sorry, sir. I wonder if Rob at can source a SKREEM for you?
This is the
ONE issue with a Crossfire I hope I
NEVER face.
