Old Feb 17, 2016 | 03:31 PM
bbrette's Avatar
bbrette
Default Fixed Ignition help!
Hi Guys
1st post and in need of help.
Had the sticky ignition problem and removed the clip inside the ignition following a guide and it worked like a charm.
Unfortunately? I did not disconnect the battery before removing and unpluging the ignition.
Anyway I reassembled everything and the key turns smooth now.
I can turn the key all the way and the dash/radio ect light up. the car wont turn over.
the sensor is in place and is not pinched or disconnected from the SKREEM.
The alarm is NOT working at all. No flashing of the lights or anything.
Key fob not working either.
disconnected the battery for around 30 min. did not work.
Ran negative cable to pos on battery. nada
Disconnected the SKREEM and battery. no go.
Poped out fuse num 9. nothing.
I'm guessing it's in anti theft mode.
Any help would be great before I burn the car down.
