Old Feb 18, 2016 | 11:31 AM
bbrette's Avatar
bbrette
Default Re: Fixed Ignition help!
That is not what you said though.
Did you reconnect the switch plug to the back of the ignition housing properly?
Disconnected SKREEM?
Sorry about that, worded it wrong.
I disconnected the SKREEM then reconnected twice. Once by itself then once with the battery disconnected at the same time and that didn't work.
I'll check the ignition housing again to make sure I put it in right, but the way the pig tail is set up it can only go back in one way.
