Old Feb 18, 2016 | 11:57 AM
onehundred80
Default Re: Fixed Ignition help!
Originally Posted by bbrette
Sorry about that, worded it wrong.
I disconnected the SKREEM then reconnected twice. Once by itself then once with the battery disconnected at the same time and that didn't work.
I'll check the ignition housing again to make sure I put it in right, but the way the pig tail is set up it can only go back in one way.
How did you disconnect the SKREEM, that is not in the instructions.
I just meant if the plug had been reconnected fully or not at all.
I would try and get a code reader to check that nothing happened coincidentally as your fix. I doubt it but ......
