Old Feb 18, 2016 | 12:59 PM
onehundred80
Default Re: Fixed Ignition help!
Originally Posted by bbrette
I only unpluged it after I did the ignition to try and problem solve as on other forum pages people had a similar problem. worked for some but not all. I'm in the not all category.
It's currently plugged in.
I cannot recall people having SKREEM problems after doing this mod. I have been here a while, are you sure you are reading posts that are relevant?
The plug in the back has to align with the tab that turns the switch. If you were you put the plug on with the key turned it would not line up and not turn the switch. That's what I recall.
