Red Paul
not fixed. It closes but is NOT flush with the car. When I lock the car with the key fob I can still open the gas door. Nothing makes it stay locked or flush with the car.
OK, one step at a time.
Open the fuel door and look at that bracket on the left hand side of the opening.
When you lock or unlock the doors using the fob do you see a pin entering the holes in the side of the bracket? You should see some movement.
This pin is what locks the cap when the door is closed, the pin goes into the hole in the tab on the inside of the gas cap door.
