onehundred80
Did you install a new MAF sensor, new MAF sensor body or both.
You need OLD sensor if you installed a new 74mm MAF body and CAI, or just the CAI.
I probably should've clarified a little bit more sorry guys, soooo basically I have had a maf code for awhile and I figured it had something to do with the way the stock intake sat on the maf sensor so I went ahead and basically made my own intake with dual filters run behind the grill. I work at an aluminum plant so I just welded my own up.
I bought a maf off eBay awhile back and tried to install it and the car ran worse than before, so I figuredit was either a bad eBay part or im not doing something right? I tried unplugging both terminals for well over an hour and checked the connections with the plug when I plugged it back in. I know some cara need to relearn a new maf sensor. I'm at a loss honestly. It'll drive but studders hard at 30 to the point I should pull over. I've also checked vacuum leaks and everything seems okay. I'm not stranger to turning Wrench's but this is baffling as hell😬
