Maf replacement and still runs cruddy
Old Mar 16, 2016 | 01:32 PM
ShufStiX's Avatar
Default Re: Maf replacement and still runs cruddy
I'll send you a pm with some location were you can find them
Old Mar 16, 2016 | 02:18 PM
MB04XFIRE's Avatar
Can you also pm me with the same info. Thanks
Old Mar 17, 2016 | 02:14 PM
pioneer4x4's Avatar
Maybe double check the wiring and connectors for the MAF. If it acts the same with both installed and/or even with none connected, I would check the connector, and all wiring involved.
Old Mar 17, 2016 | 02:21 PM
Yes, on occasion I have forgotten to re-plug my MAF/IAT after I have had the CAI off, mine acts mighty stubborn and tends to stumble without it.
Old Mar 18, 2016 | 05:35 PM
cdcrone123's Avatar
Okay late reply guys but I bought a new maf with sensor(bosh) and installed it, still running the same, which is barely at all. So I'm disconnecting the battery for about an hour and I'll go from there and see what happens. Ive also done the throttle reset to no avail. Next plan is claiming insurance because somehow my car just caught on fire😂
Old Mar 18, 2016 | 05:40 PM
ShufStiX's Avatar
Hmmmm it's weird make sure everything is connected properly , also if you shanged the sealing make sure it's good on it. And the throttle must not be tighten up like hulk would do. Disconnect the battery it helped for me too for 1 hours then try again. If you could make a video on how the engine runs maybe it would help.
Old Mar 18, 2016 | 10:06 PM
cdcrone123's Avatar
I feel like hulk is needed to change alot on this car lol. i'll make a video when I get off work tomorrow. it's my daily driver so this is a pain lol but i let it sit for 4 hours I got the same bad idle and hesitatio . Maybe I should get a computer to program it for me?
I even tried to do a throttle reset again and nothing changed..
Old Mar 19, 2016 | 05:34 AM
ShufStiX's Avatar
No computer needed to program it only thing you could do is checking again error codes. I'll wait the vid. Because now I'm kinda clueless
Old Mar 19, 2016 | 09:47 AM
cdcrone123's Avatar
I'm starting to think maybe I disconnected a vacuum line somewhere or the throttle body seal just gave out on me. Do you have a diagram I can look at and go by to check? I'll post a video when I get off.
Old Mar 19, 2016 | 11:48 AM
ShufStiX's Avatar
I dont have a diagram but look at this might help https://www.crossfireforum.org/forum...dy-upgrade.pdf
Old Mar 19, 2016 | 03:23 PM
Have you ever looked at the O-ring on the throttle body?
Old Mar 19, 2016 | 03:24 PM
ShufStiX's Avatar
Yup forgot to talk about that O-ring important to check .
Old Mar 23, 2016 | 08:29 PM
cdcrone123's Avatar
I'm a couple days late on this, but I took the car to a mechanic here in town and he wiped the codes and said I had no fuel going to my plugs. That 1,3,5 were all misfiring firing. What's weird is I've changed the plugs and wires. He believes my coils are going out but none of this happened until I replaced the maf.. Im taking yalls advice to try the o-ring next and I'm also going to change the filter for good measure. How do I go about checking the o-ring? Do I need to buy another to even check?
The drive home from the shop the car ran smooth.
Old Mar 23, 2016 | 09:09 PM
[QUOTE=cdcrone123;862518]
I'm a couple days late on this, but I took the car to a mechanic here in town and he wiped the codes and said I had no fuel going to my plugs. That 1,3,5 were all misfiring firing. What's weird is I've changed the plugs and wires. He believes my coils are going out but none of this happened until I replaced the maf.. Im taking yalls advice to try the o-ring next and I'm also going to change the filter for good measure. (NeedsWings high flow filter) im not sure if its any different but i guess ill find out. How do I go about checking the o-ring? Do I need to buy another to even check?
The drive home from the shop the car ran smooth.................
If it run smooth why not wait until you get a problem.
Deon22
49
Mar 22, 2016 10:46 AM
mebanks02
16
Mar 20, 2016 09:31 PM
1slosrt
Mar 16, 2016 01:13 PM
SeanOldaker
Mar 14, 2016 08:31 PM
Burnin Daylight
Mar 12, 2016 08:32 AM
