zip439
When you are talking about the MAF are you meaning the plastic elbow pipe or the MAF sensor that screws into the plastic pipe OR both? If you replaced the plastic pipe then you may have a problem with it seating properly. If we are just talking about the Sensor that screws into the MAF a new Bosch may cure the problem BUT, If the car is idling that bad you should have a trouble code. Have you read DTCs ?? Go to any auto parts store and ask them to read the trouble codes BEFORE you buy any new parts.
I replaced the maf and its housing piece that it comes in. When I had the car scanned previously the only code that came up was the maf malfunction. I checked all the seals and it is seated properly. Perhaps I should buy the name brand like boshe and I'll have better luck
