Old Mar 16, 2016 | 10:55 AM
PNA's Avatar
PNA
Default Re: My brakes warning light on the dash came on yesterday?
Originally Posted by kstewart
The car has 32,800 miles, I did add a tiny amount of Dot 4 wasn't low, New brake fluid added, Has not ever been change that I know of, The brake peddle does not go to the floor, just a bit mushy it seams now. I did pull all the wheels and the brake pads still look new. When I stop and turn off the key switch then restsrt the engine the Bas ESP light is out not on. But after about 5 to 10 miles it both comes on until I stop and turn off the ignition switch. Did check all the brakes lines for brake fluid and found none. Th Crossfire is not a SRT6 just a Roadster a 2005 What else do you need?
The issue you are having seems to be more and more common. There is another recent thread on the forum dealing with the same issue. I had this issue last year and am experiencing it again this year. Soft pedal. Long travel to the near or at the floor. No leaks. Full reservoir. I even had my fluid changed last year and it's doing it again this year (after sitting for long periods its worse). I had the dash light come on and go off as well. Brake pads and rotors are fine.
I'm taking mine in on Friday to have a shop that specializes in german cars look at it. I'll let you know what I find out. Please do the same if you find out sooner.
