Old Mar 18, 2016 | 10:37 AM
Yumu1009's Avatar
Yumu1009
Default Re: Need Help! P0505 idle control!
Originally Posted by velociabstract
Were you having symptoms before the work you did? I ask because I got that code when my intake manifold bolts loosen up and were leaking. Check them but be careful not to strip the bolt heads. 20nm or 15 ft lbs. Does it run good under heavy throttle? Bad at cruise and light throttle?
Les
No the symptoms appeared after my intakes were replaced. About 3 days after. And yeah casting in the car is really rough vs. Heavy throttle
