Old Mar 20, 2016 | 02:44 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: Acceleration Stall
Actually, there is not much that can go wrong with a crank sensor, after all it is simply a magnet rod with wires wrapped around it and molded into the plastic.
The most common problem with a CPS is the connector getting corroded.
The reason most here say "Go Bosch or stay home" is that the aftermarket knock-off CPS sensors have thinner connecting pins and the connector doesn't make complete contact.
JMHO, I'm sure many will disagree.
I am convinced that most of the time a good cleaning of the connector would be all that is needed. I haven't had the opportunity to test my theory yet!
