Old Mar 20, 2016 | 08:45 PM
thaiexpat's Avatar
thaiexpat
Default Re: Crossfire won't start, help!
Originally Posted by Cinema04
I'm encountering the same thing. I had my RCM resoldered months ago by a guy on this forum and that worked perfect. Recently the car died and I replaced the crankshaft position sensor two weeks ago and the car worked until last week when it died while I was driving on the highway. Had to tow it home. Replaced the crankshaft position sensor again and same no start or will start and die. Changed the camshaft position sensor today and same nothing, will start but shuts off. Just towed it to a mechanic. Hopefully it's under my warranty. What finally fixed your problem?
Success!!! So after changing both crank and camshaft sensors, resoldering the 3 joints on the RCM and having no luck, I stood and held the fuel pump contacts closed while my good lady cranked her over. Brmmmm, burst into life! So my problem was no fuel due to a faulty fuel pump relay in the RCM but despite following the good advice from the forum, I wasn't quite looking at all the areas recommended. Still not being totally convinced, I bought a cheap RCM module on EBay ($75) almost as a last resort and installed with immediate success. Frustrating and more expensive than it should have been by changing components that weren't the real problem but very happy that I finally fixed it without resorting to the local stealership. Thanks to all who gave those great tips and descriptions, I couldn't have achieved this without them.
