ala_xfire
You will see a white painted steel frame held in place with 10mm nuts.
Remove the nuts and fold back into the footwell, there is an amplifier board and if you have an automatic, the TCM module.
Thanks for the info. I am out of town at the present. I will check it out soon.
My GF just told me that when she got in the car today, the radio CAME ON. When she killed the car and restarted NO RADIO. Maybe a connection loose or bad amp.
Thanks again.
O K, today I check fuses # 8 and # 23 both good. I located the amp # A1938200489 and all wiring looks good, plugs tight and did not show any water damage anywhere. I am curious about the radio, I turn it on and CHRYSLER come up, then I push FM 1 and select a station, then in a set of numbers like 389-14 or 564-90 then radio station like FM 99.1 comes on screen they just keep repeating over and over. Still no sound : (
Please remember every now and then when I start my car the radio plays FINE. Then when I turn it off and back on NO RADIO. Very Weird. Again , I appreciate any in put. THANKS.
