Old Mar 28, 2016 | 08:18 PM
  #927 (permalink)
KDW4Him's Avatar
KDW4Him
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Deon22
Okay so I took the ignition pin out along with the spring because I had the sticky key. I hooked everything up and the car will turn over once and act like it wants to start but then die? What do I do now? Help!
Was it doing this before you did the sticky key mod?
Did you put the antenna ring back around the ignition cylinder?
