Old Mar 29, 2016 | 11:12 AM
Dcwhite67's Avatar
Dcwhite67
Default Re: 2006 infinity Radio Amp
Originally Posted by zip439
BEFORE YOU take your car any where check the fuses # 8 for the radio, and #23 for the amp in the fuse box under the hood on the drivers side. Also check with a code reader if you have any DTC Diagnostic Trouble Codes. Many items use the same grounds as the radio and amp it may help identify where your problem is if there are related DTC.
I sure appreciate your help. I will check the fuses and see if a friend has a DTC tool.
Thanks again
