Old Apr 7, 2016 | 02:38 PM
Roody's Avatar
Roody
Default 12v Supply to the Trunk / Boot
Hi All
can anyone tell me how to remove the main light switch as I want to get to the rear so I can piggy back the 12v feed so I can run a cable to the trunk / boot . Take it if was to do this , when the ignition is turned on / of the 12v feed to the rear will also be on / off. Unless any other ideas where can pick a feed up to do the same .Reason being I don't want to run a feed direct from the battery and have a constant feed when car is turned off.
There is I take it a 12v feed to the rear of the switch ???
Thanks in anticipation
Roody
