Old Apr 15, 2016 | 03:53 PM
Rob M's Avatar
Rob M
Default Re: Crossfire Wont Sart
Originally Posted by KDW4Him
Did I miss the post where he said I disconnected the battery hooked it back up it went through this three cycles of starting & stalling?
Yes, I think you did. In post #8 hardknocks6936 stated:
"yes i did.....no start after or engine crank after having the battery cables touch...."
It didn't go through any cycles of starting and stalling when reconnected.
He also replaced the battery with a new one at some point and had no crank at all.
His Crossfire degraded from initially just throwing a code to cranking with a quick stall (only twice) to not cranking at all even after disconnecting the battery. I don't see any indications of a SKREEM malufunction. That's a good thing.
Would you agree that it makes the most sense for him to first eliminate the possibility of the #1 cause of all the symptoms he has experienced? The RCM.
