Crossfire Wont Sart
Old Apr 15, 2016 | 02:28 PM
KDW4Him's Avatar
Default Re: Crossfire Wont Sart
Did I miss the post where he said I disconnected the battery hooked it back up it went through this three cycles of starting & stalling?
Old Apr 15, 2016 | 03:53 PM
Rob M's Avatar
Yes, I think you did. In post #8 hardknocks6936 stated:
"yes i did.....no start after or engine crank after having the battery cables touch...."
It didn't go through any cycles of starting and stalling when reconnected.
He also replaced the battery with a new one at some point and had no crank at all.
His Crossfire degraded from initially just throwing a code to cranking with a quick stall (only twice) to not cranking at all even after disconnecting the battery. I don't see any indications of a SKREEM malufunction. That's a good thing.
Would you agree that it makes the most sense for him to first eliminate the possibility of the #1 cause of all the symptoms he has experienced? The RCM.
Old Apr 15, 2016 | 04:04 PM
Mrmiata's Avatar
Seems "most" the times the RCM acts up is when it heats up from the car running.. but you can't rule it out. Member of the face book page.. discovered rodents had made a meal of wiring after replacing the battery for "no start".. so those are the two areas I would be looking into.
Old Apr 15, 2016 | 04:23 PM
tighed1's Avatar
He's sending the RCM in to be checked.
Standby.
Old Apr 16, 2016 | 09:46 AM
KDW4Him's Avatar
"yes i did.....no start after or engine crank after having the touch...."
OK, I took that to mean it would not even begin the three cycle crank/start/die scenario. So we have no crank with a new battery after the computer was sent out and tested good. A CEL with some unknown code.
I don't see a report of both FOB being used to try and start the car...
Yup, that leaves the RCM as the most common issue. If this were my car I would put a Bosch CPS on order for the glove box.
Old May 22, 2016 | 07:00 PM
Steve Jr's Avatar
Standby.
Did he ever get his car running? And what was it?
xfireon20z
Mar 15, 2016 04:28 PM
rtaylo
Nov 14, 2015 11:39 AM
MRGR3YXF
Nov 12, 2015 03:38 PM
stevangar
Nov 12, 2015 08:43 AM
thatcham
Oct 5, 2015 02:41 PM
