Old Apr 18, 2016 | 12:21 PM
  #930 (permalink)
breakneck's Avatar
breakneck
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Bob4kacz
Hey guys, I just did this to my car but for some reason the car just randomly locks itself when I unlock it, no alarm flash it just locks itself, seems to do it pretty consistently time wise like 30 seconds after I unlock it. Starts up fine, first time starting it after the fix it cranked but wouldn't start tried again and it ran perfectly. Any thoughts before I start tearing into it again?
So you unlock the car and don't open the door, and the car locks itself after 30 seconds? If that's the problem you're having, then it's not a problem - that is normal operation. My car does the same thing. If you unlock the car, open a door within that 30 seconds, then the car will not lock itself.
If you are having problems related to starting, my best guess would be the ring transponder is out of place.
