kingdavid54
You're correct the throttle position sensor is built into the accelerator pedal.
Au contrair, mon amee !!!!
The TPS IS in the throttle body, pop the black cover off and you will see it with it's 3 or 4 wiper arms .....
The accelerator pedal also has a rheostat that tells the PTCM the pedal position.
The PTCM takes a gander at that, then compares it with the TPS to see it it needs to open or close the TB throttle plate.
Classic "drive by wire".
