Powerloss - guidance from the specialists
Old Apr 17, 2016 | 01:57 PM
FUBU's Avatar
Default Powerloss - guidance from the specialists
Hi guys,
I am experiencing an issue with the srt-6. When I go in 3rd sometimes (not everytime, mostly if I have done a couple of pulls, temp is normal) it feels like the supercharger shutsdown.
What i have tried so far:
1. I have changed the ic pump - it runs better but did not solve the issue.
2. I have resoldered the RCM (if that had any impact I dont know but I did it) Runs better but did not solve the issue.
3. I checked the fuel pressure and it looks fine, so I guess the Pierburg fuel pump is still working fine. Also, it should be happening all the time if it was the fuel pump... or at least I think.
4. I did a throttle reset according to the guide.
So anyone think it could be the pedal sensor going bad? Something with the sc pulley not engaging? Anyone got other ideas?
Very much appreciated to get some help.
/ Philip
Old Apr 17, 2016 | 04:13 PM
FUBU's Avatar
Default Re: Powerloss - guidance from the specialists
think it may be the cps...
Old Apr 18, 2016 | 07:41 PM
Power Sedan's Avatar
Electronics are not my strength, but a year ago when I was shopping around for a SRT, a dealership in Nebraska had a silver sapphire SRT.
When I spoke with the salesmen, he had mentioned that service was fixing a acceleration issue. I had read about the IC pump issues, and assumed that would be the correct fix. However he had explained later trying to complete a sale (after my current purchase) that the accelerator pedal was in fact the culprit this particular time. It almost appears the pedal and sensor are one entire unit, but I could be mistaken.
Good luck with your search, maybe this will help justify your thoughts regarding this being a pedal sensor related issue.
Keith
Old Apr 19, 2016 | 04:00 PM
FUBU's Avatar
Thanks for the help and answers.
I went out and did some data logging. I am experiencing high IAT so I think I have a blown fuse for the pump.
I'll keep you posted
Old Apr 19, 2016 | 05:22 PM
kingdavid54's Avatar
Keith
You're correct the throttle position sensor is built into the accelerator pedal.
Old Apr 19, 2016 | 08:01 PM
Au contrair, mon amee !!!!
The TPS IS in the throttle body, pop the black cover off and you will see it with it's 3 or 4 wiper arms .....
The accelerator pedal also has a rheostat that tells the PTCM the pedal position.
The PTCM takes a gander at that, then compares it with the TPS to see it it needs to open or close the TB throttle plate.
Classic "drive by wire".
Old Apr 19, 2016 | 08:48 PM
The TPS is in the throttle body, pop the black cover off and you will see it with it's 3 or 4 wiper arms .....
The accelerator pedal has a rheostat also the tells the PTCM the pedal position.
It takes a gander at that, then compares it with the TPS to see it it needs to open or close the TB throttle plate.
Thank you George for that clarification I stand corrected your short but precise narrative makes perfect sense in fact a whole lot better since then the article I read on Benz world, how else can the computer make proper fuel calculations without knowing what position the throttle plate is in. That's the great thing about this forum, when a member bobbles the ball there's always another there to back him up and make the play at first,
Old Apr 20, 2016 | 04:25 PM
FUBU's Avatar
I'll bleed my system tomorrow to see if that helps.
Thereafter I shall also test if the pump is running
1. Check fuse
2. I did the "pump on all the time mod" today
3. Check connections down at pump
after that we shall see the verdict.
May be that I am getting a new pump, again.
Old Apr 20, 2016 | 05:23 PM
Sweet2002's Avatar
Try a dab of dielectric grease on the fitting that has the 2 wires right behind the SC pulley, worked for me!
Old May 3, 2016 | 01:07 PM
FUBU's Avatar
It is just me being stupid. I had too old coolant (mixed probably aswell) and it had started to foam up. I just had it at the garage and they have cleaned the hell out of it and bled it so now it goes perfect! So happy right now. Also credits to u guys and Rob at NW and Latemodel for the first hand help.
ENjoy the new season!
rmcdaniel12
Aug 29, 2020 10:33 AM
boostmonkey
Feb 9, 2016 09:10 PM
kolevski
Aug 3, 2011 07:08 PM
joshmo97
May 20, 2011 03:07 PM
Darticus
May 5, 2010 03:00 PM
