Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Just a note - I did my third one on Monday and it was locked up. I found that 2 of the three I've done were stickiest when it was hot out. The one I did this week was sitting in the sun with the windows up. I opened the doors and then took my silicone lube and put it in the freezer for half an hour, sprayed it in and got the key turned. Luck - yes. Repeatable - maybe , maybe not.... may be worth a try to do it in the morning when it is cooler and remember don't take the key out if it works! I also had a hard time trying to get the tumbler out so I left it in this time and it saved a step - no problems.
Reason: opened doors not windows
