Old Apr 20, 2016 | 07:51 PM
  #453 (permalink)
ala_xfire
Default Re: 62mm SRT6 Pulley Available Now
Originally Posted by rmaier
Yes that is a very good point..........denser air is harder to compress.
I found this :
Air pressure is measured in different ways. Two common ones are PSI (pounds per square inch) or a barometer which measures in column inches of mercury. As we know the barometer goes up and down with weather so the air pressure goes up and down. The highest barometer reading ever recorded is about 32 inches or just over 15.6 PSI. The lowest barometer reading ever recorded was 25.69 in the middle of a hurricane so this is not typical but equates to about 12.5 PSI. These are all sea level readings. So we need an average, or normal. The standard is a barometer of 29.92 which equates to about 14.7 PSI, again being a sea level reading. With that standard the pressure at Denver is 12.1 PSI or a barometer of about 24.63. At this pressure water boils at about 202F instead of 212F.
