Re: No power off the line
Something is wrong, peeling out even when stock is easy with this car. You floor it and the tires should break lose with no problem. The lack of power comes from when the IC pump isnt working and the blower it overheated, maybe you didnt put the pump on right?
Even then when you first start the car from a cold start you should have no problem roasting the rear.
