Old Apr 29, 2016 | 10:33 PM
KDW4Him's Avatar
KDW4Him
Default Re: Top & Rear Spoiler won't move & indicators lit
Originally Posted by blake07
Hello all,
I have problems with my 05 Roadster, I bought it some months ago and everything worked perfectly but after 2 months driving it my rear spoiler started to deploy randomly then all of a sudden it stayed deployed and the switch is blinking since then, also the Check Engine, Brake Wear Indicator, ABS, BAS ESP , Brake indicators are lit.
The Top doesn't go down either, windows go down when I unlatch it but it beeps when pressing the switch. I tried to lower it manually following the instructions in the video from https://www.crossfireforum.org/forum...operation.html
but I can't move the rear bow latch even when I try to release the Hydraulic pressure before by pressing the top switch for five seconds or leaving the top unlatched for 10 minutes.
I checked fuses all seems ok, I Just replaced battery, I tried resetting the BAS ESP with the famous left-right-center method, I checked the top switch in the trunk and seems ok.
I don't know what else to do, I really hate I can't enjoy the spring driving with my top down cause I can't even lower it manually
By the way I took the car to two different places to scan and both said they couldn't read the codes, all they got was a message the computer could not communicate or something.
I Appreciate any suggestions and advices.
BAS/ESP can only be read with the DRBIII tool. OBDII won't cut it.
There are just too many codes that bring the BAS/ESP light on to guess. Mine was a wheel sensor and the antilock brake module.
Why can't you put the top down manually?
