Old May 1, 2016 | 01:47 AM
Mrmiata's Avatar
Mrmiata
Default Re: After weeks in the shop, the car won't start
I've seen dealer replaced skreem module at 600 and out the door.. feel free to search the forum to confirm.. also a facebook page member pulled his.. sent it in (not sure where) and had a replacement coded for his car. $200 dollar DIY fix.
CPS.. car will crank till battery dies.. FYI.. a waste of money in your case for the most part.
You can play with the RCM if you like.. but you will have the same issue. No starter engagement is the result of that issue.
