Old May 1, 2016 | 03:12 AM
blake07's Avatar
blake07
Default Re: Top & Rear Spoiler won't move & indicators lit
Originally Posted by KDW4Him
BAS/ESP can only be read with the DRBIII tool. OBDII won't cut it.
There are just too many codes that bring the BAS/ESP light on to guess. Mine was a wheel sensor and the antilock brake module.
Why can't you put the top down manually?
Hello KDW4Him,
Thanks for the scanner advice. I suspect my trouble could be the same wheels sensor issue unfortunately I haven't had the chance to have it checked yet.
About the top, it seems the hydraulic pressure can't be released so I'm not able to lower it. I saw in the video the top can be put down by moving it gently but I have tried several times and It does not move so I suspect it's because of the pressure.
