bucketlisted
i just replaced the the right one, the 2 inner nuts were a bear to get to from inside the engine compartment.
I'm thinking of changing out the left one as the access door is going for the same amount as the whole fender liner.
But, there isn't any room on that side to get at those two nuts, how did you make it happen?
Are you sure they are fixed with nuts in the engine compartment, mine are definitely secured with plastic trim nuts accessed only from the inner wheel well ????? I renewed both sides with the Liners that had the fog light door already attached. I renewed both sides in 20 minutes. ?????
