Old May 6, 2016 | 08:35 PM
ala_xfire
Default Re: Inner fender liner RH
Originally Posted by TerryR
Are you sure they are fixed with nuts in the engine compartment, mine are definitely secured with plastic trim nuts accessed only from the inner wheel well ????? I renewed both sides with the Liners that had the fog light door already attached. I renewed both sides in 20 minutes. ?????
There are 2 nylon nuts in the fenderwell area, and 2 more down on the frame that you can only access by removing the belly pan.
I also installed a new set of those aftermarket ones with the door permanently attached, and mine had the lower extensions that required the two frame nuts.
