Old May 6, 2016 | 08:44 PM
bucketlisted's Avatar
bucketlisted
Default Re: Inner fender liner RH
Yep those 2 tabs that I circled in the photo are on the inside of the Inner fender liner, I made a mistake calling them nuts, actually they are 2 bolts with a large washer attached.
I can see getting at them from below as ala_xfire mentioned or as I did by going in from the engine side and performing gymnastics to get at them. Possibly they could be gotten from the other side by pulling the part back before attaching anything else. I didn't try that, but it could be the only way that I can see you getting them from the inside of the wheel well.
i
p
Originally Posted by TerryR
Are you sure they are fixed with nuts in the engine compartment, mine are definitely secured with plastic trim nuts accessed only from the inner wheel well ????? I renewed both sides with the Liners that had the fog light door already attached. I renewed both sides in 20 minutes. ?????
