Old May 12, 2016 | 04:55 PM
onehundred80
Default Re: $25.00 Paypal dollars to the first...
Originally Posted by BibaResto
...person to identify the correct wiring module for the interior/trunk 'automatic' lights that leads to my solving the non working 'automatic' lights.
To be specific, the lights that go on when you open the door, they stay on, then fade out after about 25 seconds. On my new-to-me '05 SRT-6 Coupe they do not work.
Not only do the lights work set on manual, but I've verified that the problem is not in the dome light switch. (I have an '07 Ltd coupe and the SRT-6's automatic dome light worked in it.)
The wiring diagram on 8W - 44 - 2 indicates that the dome light control is located in the Body Control Module. If you think differently and it works, fine.
The best way to indicate which wiring 'module' it is, an arrow on a photograph pointing to it would work best.
Please don't just guess.
If you recall I told you yesterday that it was the central locking pump, keep your $25, if he pump is damaged you'll need it.
The fact that your pump was wrapped in plastic bags suggests to me that the previous owner had problems. The pump may be new but the four plugs may have been damaged by water and corrosion is giving you a pain I the butt.
This is not a new problem here, there is another thread on this somewhere.
