Old May 12, 2016 | 09:38 PM
KDW4Him's Avatar
KDW4Him
Default Re: The crossfire won't turn off
Originally Posted by psuperti
My car had no power at all, it's not the battery, or alternator. Yesterday the starter engaged about 3 times and died. i eventually was able to start the engine with the terminal change. The old on was losse and wouldn't adjust. I inspected the module and the 20 amp fuse was bad. I repaired it and soldered the the 3 spots. No change, i bought a module for $198 from the Benz dl. It still won't turn off.
Is there a quick fuse I can't pull to turn the car off?
I been pulling a harness off the module to shut the car off. I went to work doing this steps.
Where to i check next for a solution?
You bought the relay module? So after the relay module replacement the car now starts but won't shut off?
Put the original relay module in, same symptoms?
I think I missed what happened between no start then no shut off. What all was done between this two things?
